2002 Fuel tank
Depends on your model. E changed in 2005 to have a strap at the rear to secure instead of two screws. Otherwise, pretty much all S and SM are interchangeable.
All year S and SM interchange and all year E and kicker interchange. Or all bikes that came with plastic tanks can swap and all bikes that came with steel tanks can swap. Be aware that CA and 49-state tanks are not the same even though they can be mounted on any S or SM. They utilize a different caps that only work with their respective tanks.
  • Like 2
To clarify, plastic tanks will bolt up to S/SM model using the E rubber frame bumper and fastening at the horn mount on the right side. The rear plastic bungee can be secured to the S/SM frame using a pipe clamp. These along with the support the shrouds provide secure the tank sufficiently.
An S/SM would only be secured on an E frame by the radiator shrouds unless simple bracket was made for the rear mounts.
Sent from my XT1650 using ThumperTalk mobile app
