Kx125 suspension trouble
I'm currently trying to change my fork seals but I can't take the spring guide out, do I just need to pull on it until it comes out?
The spring guide is the white plastic part. It should have a nut on top. If you take the nut off, the guide will come off. If you are wanting to remove the cylinder, there is a bolt on the bottom that holds it on.
