kx250f Oil leak
what to do when the weep hole on the right side of the engine block is squirting oil out when its running on a 2010 kx250f?????
Never worked on a 250 but if it's the same as the 450 there is a o ring under the cam bridge and also another gasket on top in between the head cover and cam bridge when one of these fails oil comes out the hole so it doesn't fill the spark plug chamber full of oil.
Sent from my XT1585 using ThumperTalk mobile app
