Header pipe repair recommendations
I need to get my header pipe repaired, it has a small dent and has been pushed up (from the ground)during a crash.
Can anyone recommend a good place to send for repair?20170828_205140.jpg20170828_205122.jpg
Sent from my SM-G935V using ThumperTalk mobile app
Take it off
Make room in the bottom of your freezer
Fill the header with water, closing off only one end; does not need to be water tight
Stand the header up in your freezer so the dent is on the very bottom.
Freeze it for a couple days
Dent should be gone.
If not, do it again.
That size dent is no causing any problems.....so don't worry about it
You can also wrap the dented area so that the wrapped area freezes last. That will allow the ends to freeze first, plugging the ends, forcing the dent to pop out. I fixed a dent much worse than yours using this method. It took several tries.
Sent from my SM-G900T using ThumperTalk mobile app
