09 CRF250 Rebuild advice
Rebuilding an 09 that had a rod bearing fail. I used a die grinder to smooth off the bumps where the crank web rotates. Used a file to lightly file the spots pushed out where the crankcase gasket sits. Whats y'alls opinions? Look good enough or need more work? Or should I buy new crankcase halves? Small crack through where balancer shaft goes through LH crankcase shaft.
20170828_203051.jpg.388fcc0de0177dd72c645e25d949d2ad.jpg20170828_203057.jpg.8df25d512c068ac4a32f73c5484a26b9.jpg20170828_203101.jpg.c03740b9cd1853b6b3c4007386907b4d.jpg20170828_203107.jpg.7b3d4e02f4eca72e7fad3bbc99816133.jpg20170828_203137.jpg.843c07e242ce68a7cf11f20bfb1e9c1f.jpg20170828_203147.jpg.d89b2bb153d7eb2d4cda90c17e14f8c0.jpg20170828_203151.jpg.3acf051ad752be8aac0c4b10e76cce11.jpg
Sent from my SM-G920V using ThumperTalk mobile app
Doesn't look terrible. Make sure there is nothing embedded that could flake off. As for the gasket surface you really need a large surface plate with a very fine grit sand paper to flatten the sealing surface. Remove little material as possible.
