identify this spring?
I found this under a 2001 XR250 and I don't know if it is for the bike. The only work I was doing at the time was a valve check, and I also disconnected the manual decompressor cable to re adjust that as well.  Anyone recognize it? As I said, it may be even be for this bike, but I want to be sure.
Looks like the spring from the front brake lever didnt see a spring like that during my rebuilt but i had earlier model
Thanks. I don't claim to be a good mechanic, but if it is fro a front brake I'm worse than I thought. :(
Edited by dogeddie
Im not saying it defo is just looks like the one that goes in the front brake lever , i didnt recall seeing such spring within the rocker cover
I know - just being a funny guy... It is possible it is from another of my victims
Trailryder - thats it!! Thank you!! I was trying to start the bike and unscrewed the nut inside the plug boot. What order does it go back in?
I would say, in the order shown in the picture. Imagine the plug boot laying to the right of the spring in the picture.
Don't know what you were trying to accomplish with unscrewing the resister screw for starting purposes, but it is not adjustable that way. Install the components as shown and snug the screw.
Edited by Trailryder42
Thanks. I was seeing if there was anything that would prevent a good connection. I don't recall any copper piece in my setup though - just the screw, the red/white piece, and the spring (which I obviously DIDN'T know about). Is the copper piece a replacement for the red/white piece or something?
Nevermind - you must've replaced the resistor with the copper piece - thanks
Edited by dogeddie
Yes, the copper slug is a popular XR mod. It replaces the resistor. One less thing that can fail. The copper slug has a lower resistance than any metal besides gold.
On ‎31‎/‎08‎/‎2017 at 6:46 AM, geezer99 said:
Actually, conductivity champs are in this order:  #1 silver, #2 copper, # gold, #4 aluminum
More here:  https://www.thoughtco.com/table-of-electrical-resistivity-conductivity-608499
interesting....... I wonder why they use GOLD plated terminals in low resistance applications  such as mobile phones, computers and metal detectors if silver is better??? and a whole lot cheaper..... sounds a bit dodgy to me
Because gold doesn't oxidize like silver, copper, and aluminum.  Silver is the better conductor.
I used a stainless steel bolt.  It's so large compared to the load, there's little resistance and no corrosion.
Edited by Baja Rambler
don't like to argue but that sounds contradictory.       as for the stainless steel bolt im guessing this is for the ignition coil resistor replacement???
Go ahead and look it up in any encyclopedia.
In WW2 we had a shortage of copper so used silver wire to wind motors for centrifuges on Manhattan project. 🇺🇸
And yes,  stainless for resistor replacement.  Brass can also be used.
Gold works because it's not a soldered connection so corrosion between contacts is the issue there.  Once soldered, oxidation is not so much of a problem.  So yes, gold plated silver would be a great replacement for the resistor, second only to being soldered or one whole piece.
yehh is ok I guess you don't see what I see. I get that a lot being    as    is all good?
Respectfully, what do you see?  Maybe I can learn something.
I edited previous post.
