Xr400 choke cable
Being that the choke plunger has a detent in it to keep the choke on once pulled, A cable pull would likely work for pulling the choke, but not pushing it back in. the CRF250X has a hot start cable that has the same thread size as the choke plunger. If the threads are the same as the pumper carb you have now, might be able to make it work. can you get me a measurement of the thread size and depth on the choke plunger you have? I have a hot start cable I will sell cheap if you want it and it works. you'd have to use a clutch perch with a hot start lever on it as well.
