Please help Yamaha DT 100
I can not figure out why my Yamaha DT100 wont get spark. It has power coming from the points and I have bought a new coil and it still wont get power out of the coil and i made sure the coil has a good ground, I'm thinking it could be that there is not enough power for the coil because the bike only has six volts and I am not sure if the coil can be 12
Edited by Michael Martin
Are you sure it's timed correctly and the points or condenser aren't grounding?
Sand between the points gap with 400 - 600 grit sand paper
Check the points B.T.D.C gap to this
