Help oil issues
Hey I'm a two stroke guy and I just bought a four stroke... I rebuilt it and want to know what types if oil to run... I know there are two compartments but what do I put in each... Want to know name brands and types and what side to put them in transmission side or engine side. And what coolant do you reccomend! Thanks
Edited by The KXMAN
I hear TT is making a t-shirt about the much repeat whats the best oil question :)
Otherwise
IMO on my 05, I use an hour meter and replace both oils and filter MAX 10 engine hours or as low as 4 hrs depending on how, where I ride.
Maxima SynBlend 4 10w40 engine oil
Maxima MTL 80WT tranny oil.
Hiflofiltro engine oil filters.
Maxima Coolant 50/50 cus it occasionally  gets below freezing in the winter where I live and I usually ride 365 and store my bike out side 365
Well worth the $$$ to replace regularly with the best quality stuff you can afford cus I have about 275 engine hrs on my bike since the last top end and piston. Other peoples results may vary
