Keihin fcr 40 idle screw issue
So my extended idle screw on my fcr 40 does not turn smoothly and during adjustment it feels like the spring wants to bing up and if you don't turn enough it bounces back. Any ideas or is this not
Normal.
Normal.
Not normal.
If it's a cheap aluminum screw replace it with an R&D flex jet fuel screw.
Sent from my XT1650 using ThumperTalk mobile app
38 minutes ago, ohiodrz400sm said:
Not normal.
Honestly I think its the stock screw. And I meant to say bind. It's like it gets to a certain point turning in or out and it comes in a slight bind and then if you pass the bind it either idles up or down to much. I hate the location of the mixture screws on the FCR 40 carbs.
Edited by IraqvetUSMC
He said IDLE SCREW
If he meant idle screw, then the idle screw (which is extened) spring cable has broken, or is about to. Replace it.
 Pull the throttle wheel cover off to inspect.
Not normal.
Yeah, it may be time to have my eyes checked.
