RMZ Idle Help!!!
I have a 2010 Rm-z 250 that will not idle below around 3000 rpms. I have tried cleaning the throttle body several times. I adjusted the valves (which were way out) and checked the tp sensor and adjusted it. The bike supposedly has had some engine work done to it. It has a full FMF system on it. I just got a fuel programmer and am messing around with that and having limited success. It can turn the idle down to 2800 or so and it will run for a little bit and then eventually die. PLEASE HELP!!!!  Thanks
