DRZ400 Loctite fix - Compact version / Cheat Sheet
Image description:
  • A, B, C (Stator)
    • Medium strength thread locker (Loctite 242 or equivalent)
    • A is 2 bolts. B is 3 bolts. C is 1 bolt.
    • Torque for A is xx Nm. Torque for B is xx Nm. Torque for C is xx Nm.
  • D (Starter clutch)
    • High strength thread locker (Loctite 271 or equivalent).
    • 6 bolts.
    • All six of bolts should be replaced with new, high grade allen head bolts, regardless if they appear to be acceptable.
    • Torque is 8 Nm for stock bolts. 12 Nm for high grade allen head bolts.
In depth: https://thumpertalk.com/forums/topic/548456-stator-and-starter-clutch-loctite-fix/
Why this: Needed to have a compact version to show mechanic. Maybe others find it useful.
Disclaimer: Info resourced online, use at own risk. Double check torque specs.
Edited by Hugh Dick
why?
