02 cr125 PWK thoughts.
Hey guys!
So I have been getting some time on my 02 cr125 (Eric gorr 134 big bored). I recently did a PWK 38 (from a 92 kx250) swap along with the 05-07 air boot swap. Here are my thoughts.
#1 - started at a 185 main, 50 pilot. Using a red JD jetting needle from a 03 yz250. It has the #5 slide. Right away when I put it in, it sounded a MILLION times better. Sounds almost 250 2 stroke like. Much deeper and crispier.
#2 - if you do not like tinkering with jetting ( or do not know how to), this is NOT for you. You need to know what to listen for while jetting it. I have been through over 5 spark plugs trying to jetting it mostly dialed (feel like it is just a tad rich right now).
Elevation - 2,000 ft Temp- 80-110 deg
Jetting:
Needle 3rd pos
170 main
40 pilot
#5 slide
#3 - Right away, it wants to move! It lost a little bottom end grunt (your not riding a 125 2 stroke for bottom end grunt lol), but gained a LOT of top end! The closer I get it to the perfect jetting, the better it feels!
Final thoughts: it is a awesome mod to do if you know what your doing. It is a night and day difference in power! Definitely easier to ride in the power band and I actually like it more than my other 125's. if your thinking about it definitely do it!
