Oil scavenger pump?
Just purchased 05 ktm 525 that leaks oil out of bent tube, has fresh rebuild so I know it's not the rings what is the scavenger pump and if changed with that fix my problem? Please help me thanks
A fresh rebuild may still have a bit more than normal blow by until you get a few hours on it.
Do a leak down test if it's actually broken in. It's possible whoever installed the rings did not properly gap them.  Reroute your vent tube to under the seat. I install a little vent filter on the end of the hose.
