Will yz450f 19" rear hub and rim slot straight into a yz450fx swing arm?
Hi, I've searched high and low through forums and t'interweb and can't find any info on the differences, if any, between the swingarms. Seeing as they're near identicle bikes until the 2018 I'm hoping the 2016 or 17 models have interchangeable rear wheels. I ride in the desert with the yz450f and am looking at the fx for the bigger tank options and wider gearing but I prefer the 19 inch wheel for the 410 semi-sand tyre and reduced weight, pinch flats aren't really a problem. Any ideas?
I am not up on my FX stuff but I assume if the FX runs the 25mm axle it would be a straight swap. All spacing on modern YZ and YZF wheels are the same with any differences beimg in the spacers and axles.
Sent from my SM-G955U using ThumperTalk mobile app
