1993 Honda XR250R Fuel Tank question
I recently picked up a 1993 Honda XR250R. It's pretty rough on the outside, but seems pretty good on the inside after some TLC. Going to ride it for the rest of the season, then will strip it, refinish it over the winter. The fuel tank is in really rough shape, not sure if any amount of sanding/polishing is going to get it looking decent.  So I'm looking around and not seeing much for tanks other than humongous ones. I don't need anything bigger than stock, and I really would like to get a red tank. The question is, what years fit a 1993? Is it year specific or is there a range of years that would work? Thanks, Chappyd
you'll need one for the year range, so pre-1996 in your case.
i have a 1991 xr250 and fitted a later tank in error, you need to make some small brackets as if you bolt it up the holes, the fork legs bang on the tank before the steering stop. having made the brackets its fits ok but i have a non standard seat so can't vouch for how it fits with the standard seat
