CHEAP DR350 - Do I buy it?
I need a rational person who has dealt with DRs.
1992 DR350
28K miles
800$ - everything works so he says
He says it has electric start... but it must be aftermarket. It does appear that this may be a bit of a basket case. I'm handy and am not afraid to tear a 4T down to the crank bearings. It's an adventure!
The question; is 800$ worth the work it probably needs? I can get one that looks better for $1500-2000.
I've purchased basket cases before just for the entertainment value, but it can be really easy to bury yourself on the wrong 'lost cause.'
https://www.ksl.com/classifieds/listing/45280836
Basket case?  $250 for one that old.
I'd pass. Get one with low miles for 1500. The entertainment value is fun but in the end it's just a bad re-run.
Ok good, that's the affirmation I needed. Thanks!
electric-start engine & big desert gas tank. definitely worth 800 if everything works
If it works, I would take that in a heartbeat!
Agreed, not a bad deal with estart and upgraded tank. Doesn't look like a basket case to me, actually looks pretty clean and listing says everything works. 23k miles is up there but if cared for it should have many miles left.
the mileage is irrelevant since the engine is a transplant.
Indeed, unless they were transplants from the same bike, which seems quite possible. Not much detail available.
actually impossible as the electric-start DR350SE engine began in 1994, the DR250SE began in 1993.
look at the cylinder base on the left side to make sure its a 350:
oh, you meant the odo & engine. i was thinking the odo would probably be from the frame
Yeah, odo and engine. I don't know the models really well, but if the bike is a '92 that would mean the frame is a '92 right? So the odo/motor/other bits might have come off a donor bike? I guess the seller could answer all that lol
Either way, in these parts you don't get a street legal DR in good shape for under $1k, seems like a good price.
I am living the decision that you are pondering. I got a 98 DR from a friend who had a bad crash on it last year and parked it afterwards,  but I hadn't ever really checked the bike out prior to buying it even though I had worked on it a few years ago. I just had him drop it off at my work, I figured a 1998 with 4500 miles for a grand. how bad could it be?  Well a lack of maintenance by the previous owners and Somewhere along the way some work was done by someone who shouldn't be allowed to hold a tool in their  hand. I thought the bike needed a good cleaning. My goal was to clean it up, new plastics and seat cover and I would have a buddy bike, right?   Not so fast. Blown shock that someone had "lowered", clogged carb, seized bearings in the swing arm that needed to go to a machine shop and be cut out. Dead battery, valves past the end of adjustment, yada yada yada. I really want this bike to be correct and it will, but at a cost. My advise is NEVER buy a bike without a complete history of maintenance and mods done. The last thing you want is a surprise that is going to cost you time and money...
Late to the thread.....and obviously quasi resurrecting it.  I just bought a 1997 350SE that needed a major carb rebuild (took me 3 hours just to get some of it apart and cleaned!) with 7200 miles on it for $900.  Just sayin.  I feel like a bike with those issues, those miles, and that old should be nowhere near $800.
what price would you say then?
Hell....I would hit him at $500.... The worst he would say is NO.
on the other hand, if i were the seller i wouldn't take less than 1500
Edited by plugeye
I try not to comment on price because different parts of the country can vary by a lot.  Normally I suggest that you look through the local craig's list ad's, check NADA, factor in condition and how much it's going to cost you to get it to a level that you want the bike to be in ~ then go shopping.  When the numbers work go for it.
In the case of that DR350 I can't comment because the ad has been pulled, but by going off of just what the OP stated, $800 in my area could be reasonable.
And then you keep it longer than you'd like.
