Leak from nipple of 2 cycle oil reservoir
Hi, I have my 1978 Kawasaki KD 175 that i have been fixing up, and have noticed a leak in the 2 cycle oil reservoir. It is coming off the nipple that sticks out that the hose connects too. The hose cannot go over the crack on the nipple so it just leaks everywhere. I am wondering if there is anything i can put on or do to crack to stop this leak.
Thanks, Jake
Thanks, ill try to use a soldering iron, ill probably have to plastic weld a small piece onto the nipple to fill the crack
Use as small an iron as possible, and be careful when applying heat. You don't want to break through that thin wall.
Theres quite a few second hand ones on Ebay in good condition
All these use the same oil tank
1974 KS125 OIL TANK-SIDE COVER ('74-'75)
1974 KS125 OIL TANK-SIDE COVER ('76-'79)
1975 KD125 SIDE COVER-OIL TANK-CHAIN COVER
1975 KS125-A OIL TANK-SIDE COVER ('74-'75)
1975 KS125-A OIL TANK-SIDE COVER ('76-'79)
1976 KD125-A2 SIDE COVER-OIL TANK-CHAIN COVER
1976 KD175-A1 SIDE COVER-OIL TANK-CHAIN COVER
1976 KE125-A3 KE125 OIL TANK-SIDE COVER ('74-'75)
1976 KE125-A3 KE125 OIL TANK-SIDE COVER ('76-'79)
1976 KE175-B1 KE175 SIDE COVER-OIL TANK
1977 KD125-A3 SIDE COVER-OIL TANK-CHAIN COVER
1977 KD175-A2 SIDE COVER-OIL TANK-CHAIN COVER
1977 KE125-A4 KE125 OIL TANK-SIDE COVER ('74-'75)
1977 KE125-A4 KE125 OIL TANK-SIDE COVER ('76-'79)
1977 KE175-B2 KE175 SIDE COVER-OIL TANK
1978 KD125-A4 SIDE COVER-OIL TANK-CHAIN COVER
1978 KD175-A3 SIDE COVER-OIL TANK-CHAIN COVER
1978 KE125-A5 KE125 OIL TANK-SIDE COVER ('74-'75)
1978 KE125-A5 KE125 OIL TANK-SIDE COVER ('76-'79)
1978 KE175-B3 KE175 SIDE COVER-OIL TANK
1979 KD125-A5 SIDE COVER-OIL TANK-CHAIN COVER
1979 KD175-A4 SIDE COVER-OIL TANK-CHAIN COVER
1979 KE125-A6 KE125 OIL TANK-SIDE COVER ('74-'75)
1979 KE125-A6 KE125 OIL TANK-SIDE COVER ('76-'79)
1980 KE125-A7 KE125 OIL TANK ('80-'81 A7-A8)
1980 KE125-A7 KE125 OIL TANK ('82-'83 A9-A10)
1981 KE125-A8 KE125 OIL TANK ('80-'81 A7-A8)
1981 KE125-A8 KE125 OIL TANK ('82-'83 A9-A10)
1982 KE125-A9 KE125 OIL TANK ('80-'81 A7-A8)
1982 KE125-A9 KE125 OIL TANK ('82-'83 A9-A10)
1983 KE125-A10 KE125 OIL TANK ('80-'81 A7-A8)
1983 KE125-A10 KE125 OIL TANK ('82-'83 A9-A10)
Thanks, I actually ordered a 1977 K125 oil tank yesterday. Not sure if he meant KD125 or KE125 but it look pretty much identical to mine
:thumbsup:to S.O.A.N.Z
I checked e-Bay also before posting a repair option, but only searched for your model, not interchangeable models.
