Recluse clutch brake tap in the air ?
Has anyone with a recluse clutch brake tapped the rear brake while in the air to drop the front wheel without using the clutch lever ? I'm thinking the engine won't stall in the same way when rolling to a stop without using the clutch lever and the engine doesn't stall or dropping the bike in a berm the bike keeps running which I love about this clutch ! I'm fairly new to motocross, I can jump pretty good but I have had a few bad crashes jumping. I want to try brake tapping but want to try and prevent anything going wrong.
Mine will stay running with a brake tap as long as I am totally off the throttle. I've had it stall if I'm still on the throttle a little & brake...
Sent from my SM-G390W using ThumperTalk mobile app
