Can't figure out this squeal, HELP!
So I've been really struggling trying to figure this one out.  I've done the clutch push rod flattening, etc.  Still no success on solving this noise.  Bike runs great but like clock work the noise returns once the bike is good and hot.  With the bike in neutral it does tries to "engage" the transmission when the squeal occurs.  I've replace friction/steel plates, push rod (tried stock and modified with flat ends on push rod), needle bearing with adjusting washer.   the noise definitely sounds like its come from the countershaft sprocket area..  Any help would much appreciated!!  The bike is 2013 KX450F
Thanks!!
Ethan
I have a 16 and the squealing was there. I knew about the problem and just said whatever and ran it. Went away and never came back.
Sent from my VS835 using ThumperTalk mobile app
