bike stays in gear while holding in the clutch
I have a 04 rmz 250. So far ive rebuilt the top end, replaced my clutch plates and springs and new plugs.
My problem is it wont keep idle(stalls after 30secs) and when its in gear and I hold the clutch in it stays in gear.
please help !!! I want to go for a rip before the snow comes !!!!
So you replaced the clutch plates and now the clutch does not release.  I think you should start there.  If it will not idle in neutral you have other issues as well.
I had the clutch problem before hand.
What I read told me that if I'm in gear and not moving just raving that my plates are done. Also when it does run I can kick it in gear without it stalling but it won't but can't walk it. So it's in gear(won't stall) but won't go neutral while holding the clutch
thanks I got It. it was the clutch plates I switched them up and got to go for a good boot. unfortunately I only got about an hour ride in before it stalled and wouldn't start back up. thinking I didn't shim it properly or fried my rings.
