Cam advice 470 (promise I searched)
So it's likely a 462?
Yes.
The "470" was built using a +5 stroker kit. Those kits have been discontinued I believe.
Sent from my XT1650 using ThumperTalk mobile app
Getting ready to order a shim kit and a few other things.  Anyone know where I can find the correct head gasket? I'm stumped.
Also, do I need a new base gasket if I didn't take out the last 2 bolts on the side holding the cylinder down?
I've been soaking the head/ valves in carb cleaner to cut some of the carbon and i haven't had any leak down in 2 days, so the valve seats I assume are good.
However there is a ton of build up inside on the exhaust side. Not sure why, but they are as filthy as my piston was. I'll clean those up before I try to remove them.
Going to order a head gasket online tonight and then I should be ready to start assembling once it's all cleaned up
Edited by Savage422
On 9/12/2017 at 7:18 AM, ohiodrz400sm said:
What kind of valves and tensioner do you have?
Just looked up the part numbers on the receipt. Kibble white valves
0296-0217 and 0216
Cam cam journals be repaired?
Or am I looking at a new head?
Can be fixed
12 minutes ago, ohiodrz400sm said:
Can be fixed
Awesome. I'll send it to fastheads as is.
Send them the pics and talk to them 1st
Definitely 👍
*cam cradles*
5 minutes ago, Bermudacat said:
*cam cradles*
Yeah, that's what I said. Lol 🤣
I was doing a search for repair on a head that I bought, and that was the vernacular that landed the most hits. Some place that does KTM heads said they can do the Suzuki.
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
