Rear spring removal!!!!!!!
How do I relieve the actual spring off this bike, there's no way I can see to remove the shackle off and take the spring out but anybody know!!!!
The aluminium 'cup' you're tilting in the pic is actually 2 pieces,
the 'cup' and an 'outer spring seat' which you must tap towards the spring to expose a lock ring.
Myself insert 2 flat metal files between the shock spring and cup, then tap with a plastic mallet.
That recess often packs up with dried dirt, spray some WD-40 etc. and let it soak for a few minutes.
Once the lock ring is removed the outer 'spring seat' can then pass around the cup and clevis (shackle)
also allowing the shock spring to be removed.
Edited by mlatour
