What kind of bearing?
Hey Guys, An Aussie here just wondering if anyone has replaced there counter balance shaft bearings with non oem and what exactly am i to look for? i see there are all sorts of load thrust bearings etc.. i hope it's not just plan ball bearings in the correct size
My DRZ400E 06 dropped a valve and demolished the engine i have already ordered aftermarket crankshaft bearings (HotRod)
Take an old bearing to a bearing supplier if you dont know what you need and get a replacement like for like. They will look at the codes on the bearing to see what you need
Go for koyo ntn or skf bearings
Suzuki dont make bearings and like the other Jap manufacturers they use koyo or ntn bearings.
If you buy oem suzuki bearings they often gome in the koyo or ntn box
I never use oem bearings as they are over priced, unless they are specials which you can only get from the oem
