2010 kx450 clutch won't spring
I was riding my kx450 yesterday and out of nowhere my clutch cable broke. So I put another one on but now there's no spring to it. When I pull the clutch in it just stays there. I'm not sure if a small part fell of or something. I posted a picture in case that shines any light that I'm missing on the problem Any help you be really appreciated.
I can see on the picture tou have it on wrong, the metal tube on the left thats connected to the holder is pointing down and it almost looks broken because the nut and tube should be leveld each other because the nut is screwed to the tube , but now it looks like 2 pieces
Wires is VERY sensitive to bending and how you rout it if its not on exactly right it will bind and you have this problem
Re-rout and check the manual if you are unsure how it should be.
Edited by skorpan777
