Fork preload on 2010?
Is the fork preload not adjustable on the 2010 250?
My service manual says I should have the SFF fork with compression on the left and preload on the right.... but both my fork caps looks the same - both with compression. So since it isn't SFF, where's the preload adjustment?
Edited by Jared Barnes
On 2017-09-15 at 11:03 PM, Jared Barnes said:
Bump... so no preload adjustment on these at all?
Not externally, you can shim the spring to add preload.
