2004 yz85 super low rear shock
Hi just wondering if anybody knows a good rear shock replacement for a 2004 yz85 the 1 thats on there is very low in height especially when you sit down on it goes down alot.. looking for a shock to raise the bike up alittle any ideas or help?? thanks
First determine if the spring on the shock is correct for your weight and riding style. This will be a starting point for getting your bike to the proper height.
http://www.dirt-bike-secrets.com/spring-rate.html
http://www.racetech.com/page/id/147         Pick "Calculate Spring Rates and Display Available Springs"
Good luck, and keep us updated with what you find. :thumbsup:
Have you set the sag on the rear suspension? That should set the correct height at the rear without rider. Sorry, I should have mentioned that first. :facepalm:
http://www.dirt-bike-secrets.com/motorcycle-suspension-setup.html
stronger spring (that won't compress as easily) may be what you need to get your bike to it's proper height with rider.
Suspension setup is super important on dirtbikes, so it pays to adjust all the settings. Again, sorry for my oversight. :thumbsup:
