KX125 Shock Rod
Hi Members,
I'm dismantling a friends bike so we can fully check/service/repair it.
When I removed the shock I found damage to the rod, here:
Whoever "serviced" it last must have used pipe-grips or something similar to keep the rod from spinning when removing the nut.
My question is about whether this rod needs to be repaired (if possible) or replaced?
Any input will be massively appreciated.
Thank you in advance!
it will be ok - the rubber bumper stop covers it
There's no chance of seals etc travelling to that area in use? I've cleaned up the rough and jagged areas with a small file, so it's smooth again, but still ugly Lol
Why in the hell are you taking it apart on that end?!
The owner didn't want the actually body dismantled. I told them to rebuild the whole thing but I'm just working on what they asked, hence only working at the one end.
The correct way to replace the seal is to remove the entire assembly from the shock, grind off any peening on the end of the shaft (if any) and remove the piston then seal head.  The clevis stays on the shaft unless it's damaged.  It's alot easier than trying to work how you are doing it.
Noted! Thank you for the feedback!
And good luck on getting a deal head over that end without tearing up the seal.
The worst part is, I only removed the shock from the bike. The owner of the bike removed the parts from the shock itself - so now I need to try and figure out the mess he's made.
It sounds like he's put me in an impossible situation? I'll be having a fun weekend.
If you or anyone is that concerned with the shock just buy a decent used one and swap over the shim stacks.
I did mention to him that getting another shock would be a good move for spares, now it seems a necessity.
I'm assuming you're a little new to shock rebuilds so here's some tips so you don't get yourself in a jam.
If the shock is original, the nut holding the piston on the shaft was peened from the factory.  Wrap the shim stack/piston with some paper towels/plastic bag and gently grind off the peening just until the nut can be easily removed.
When you remove the valving, place a screwdriver over the end of the shaft and slide the valving and piston all together to the screwdriver, that will make sure everything stays in order. Use threadlocker on the nut after it's all together and keep everything clean.
Other than that, follow the directions in the shop manual for bleeding and assembly.  I made up a funnel I use to "over fill" the shock while I bleed to try to eliminate all traces of ait.
Edited by Jeekinz
I really appreciate this! Thank you for taking the time to share it! I have a manual as well, so I'll get into this properly!
