Electric Dirt Bike that’s going to be a Game Changer – Light Bee
LIGHT BEE
Electric Dirt Bike that’s going to be a Game Changer – LIGHT BEE
This Electric Dirt bike is made flawlessly. The quality is awesome, the parts used are high quality and the company behind it is very serious China Design and Engineering company. They pride themselves with their design capabilities and they are making efforts to supervise and make products that are actually designed from bottom up. No copy, no shitty parts. Pure R&D.
Aluminium forging (Forging is a manufacturing process where metal is pressed, pounded or squeezed under great pressure to produce high-strength parts. Forged aluminum is ideal for applications where performance and safety are critical but a lighter-weight metal is needed for speed or energy efficiency.).
The Frame – weight: 7.8 kg
For Aluminium forged parts you need to invest more money at the beginning, but afterward, parts are inexpensive and still super smooth looking.
As you will see later on; the chosen components of the bike are HIGH END, the speed and power is not jeopardized. We are pretty sure that they are going to crush the Electric Dirtbike market.
They are made out of two teams. Hangzhou team is responsible for intelligent system research and development, Chongqing team responsible for vehicle research and development. Together with the vehicle for independent design, research and development; complete intelligent system design, research and development, user experience tracking and data collection, analysis.
FRAME DESIGN AND DIMENSIONS
The Electric Dirt bike frame weight is about 7.8 kg made with 6,000 tons of pressure. Fully forging lightweight aluminum alloy frame with high-quality inspection standards
Professional off-road vehicle rear and front angle,high seating position and comfortable soft cushion
BIKE DESIGN TECHNICAL SPECIFICATIONS
o LENGTH: 1870mm
o WIDTH: 780mm
o HEIGHT: 1040mm
o MINIMUM GROUND DISTANCE: 270mm
o WHEELBASE: 1260mm
o VEHICLE QUALITY: 50kg
o FRONT AXLE MASS DISTRIBUTION: 24kg
o REAR AXLE MASS DISTRIBUTION: 26kg
o MAXIMUM LOAD WEIGHT: 100kg
TIRES AND BRAKES
o TIRE SPECIFICATIONS (FRONT): 70 / 100-19
o TIRE SPECIFICATIONS (AFTER): 70 / 100-19
o RIM TYPE (FRONT): 19×1.4
o RIM TYPE (AFTER): 19×1.4
o BRAKE TYPE (FRONT): to the four-piston hydraulic disc brake
o BRAKE TYPE (REAR): to the four-piston hydraulic disc brake
We offer options for buyers for Dirt Bike front fork; RST or Fastace
THE BATTERY AND CONTROLER
The best controller (48-80V) with all features you are used to. Torque control, speed limit etc.
We use Panasonic 18650 pf cells and assemble them ourselves in Abs case packs shown above
There are two versions of this Electric Dirt Bike BATTERY SYSTEMS:
1.First Version uses 140 Panasonic 18650 cells – 48v 25 ah
2.Second version uses 176 Panasonic 18650 cells – 60v 32ah
BMS STATISTICS
High-power BMS
SOC statistics
4 temperature sensor real-time monitoring
Host computer management program and data interface
The battery pack is rated for 500 cycles at 80% discharging
The battery case is removable – so it’s not necessary to have infrastructure around to recharge the bike. Its light enough to take it home and plug it into the wall socket
THE MOTOR PERFORMANCE AND TRANSMISSION
Motor used on this bike is Golden motor. Its one of those Axial flux motors that are known for good performance
Model: HPM3000B — High Power BLDC Motor
1. Voltages: 48/72V
2. Rated power: 2-3KW
3. Peak power: 6KW
4. Speed: 3000-5000rpm
5. Rated torque: 10 Nm
6. Peak torque: 25 Nm
7. Efficiency: >90%
8. Dimensions: 18cm dia. 12.5cm height
9. Weight: 7.3kg(air),8kg(water)
10. Cooling: air or liquid cooling
TOTAL SYSTEM TOURQ IS 200 Nm
You get this number by multiplying the belt and chain ratio with the motor tourq
Performance and transmission ( Double stage transmission )
o MOTOR MAXIMUM SPEED: 4500r / min
o COOLING METHOD: forced air cooling
o CLIMBING ANGLE: 35 °
o ENDURANCE: 100km (20km / h speed)
o MAXIMUM TORQUE: 200N.m
o TRANSMISSION TYPE AND TRANSMISSION RATIO: 1: 7.6
o DRIVE: belt + chain
o BELT SPECIFICATIONS: HTD 8M CXA drive
DASHBOARD AND SYSTEM COMPUTER
The dashboard features all functions you are used to. We don’t feel its necessary to count them all here
Information avaible over dedicated mobile app
Real-time understanding of vehicle information, view the driving track, Record the history of the trip, but also understand your APP GPS vehicle positioning, security, security, more secure APP In the riders to share the fun of riding, discuss light bee play, more interesting APP
All together taken into account, it’s the smartest production Electric Dirtbike from China up to this date in terms of what market actually needs right now.
TB2FV.OdTAlyKJjSZFhXXc8XFXa_3280167576.thumb.jpg.14608771ee2f1dd395a65f2240294748.jpg
This was all I needed to read ....  Bahahahahaha !!!!!!!
And those 2 sentences should NEVER be used together.
Could you imagine eating CHINESE SPAM ! YUK
Yours is an electric mountain bike.  Nothing wrong with that.
KTM is developing THE electric dirt bike.
Edited by Jeff aka Bolt
Kind of interesting as a sort of pit bike like thing. No mention of price or where to buy.
These bikes have hit our shores and are looking good but they raised the price to $3500.
The fork was bottoming out on rolling whoops!!!!  Not even jumps!! Thats some seriously soft (or total shat) suspension there.
 Look at the welds (or attempted welds) on the pic that shows part of the frame. Seriously scary lack of connection there.  I wouldn't trust my ass on that bike.
I'm thinking about it, price seems not bad for a pit bike, seems like it would be decently fast. Fun for the house.
Wish I could take one for a spin tough. Not sure I want to chance $3500 on something like this, could be hard to resell if it doesn't meet expectations.
Doesn't seem like this thing really got off the ground. Doesn't seem like you can buy it any where yet. I don't see any new info from a google search.
