Black plastic sheathing around front brake line?
My front brake line sheathing/protector is rough looking on a KX250 I'm restoring and am trying to think of something I could use in place of the OEM one. Brake line is in good shape so would rather not replace it.
Has anyone used something else, maybe from a big box hardware store or something?
Sent from my ONEPLUS A5000 using ThumperTalk mobile app
24 minutes ago, SnowMule said:
Use the dual-wall adhesive-lined stuff.  The cheap 2:1 crap from hardware stores won't stay put.
Are we talking about shrink tubing? If so, would I just get something big enough to fit over the banjo bolt area then heat it up with heat gun to fit it to size?
How about a way to replace the hard plastic sheathing that goes pretty much the whole length of the brake line? I have a tear at the bottom which is exposing the braided brake line.
I would not remove the hard plastic sheathing, just put shrink tube over the bad area. Yes, get the shrink tube big enough to go over the banjo end.
Galfer BOGO special is the way to go. Unbeatable price , great products, good folks to deal with. Can't loose. It's what you need.
I'm in the electrical business and there are a few options for shrink tube and yes, use a heat gun or if you are REALLY careful, a propane torch.
What  is T&B Heavy Wall shrink tube in a 48" length HS12-6-4. IMO this stuff is BOMBER and it has sealant inside it and there are lots of other use for it :)
http://www.tnb.ca/en/pdf-catalogues/wire-termination/heat-shrinkable-tubing/C-Heat-Shrinkable Tubing-E.pdf
I use about a 6" length at the bottom over the bango, then about 8" where I have the cable running in front of the number plate red arrow.
For the section between there (green arrow), I would use the medium wall stuff but remember it will shrink down about 1/3 of its inner diameter.
Have never had that happen, problem with your routing or cable guides?
I think it was caused by a guide added to the front # plate. I didn't really inspect the situation before I tore it apart.
Might be time to just replace the line.  :excuseme:
It's really not bad but I hear ya!
Good call, good price! Thanks
Awesome, maybe I'll salvage this line after all!!
Thats my OEM front brake line from 2005 :)
