SHOOOT ME NOW ! Stripped threads - 6x120mm
After we replaced the 600 head gasket on the 650, then replaced the cam chain tensioner that was installed to ride the chain instead of the guide.... ( Fungles courtesy of professional bike shop, not me)
now we have a ...  wait for it....
stripped bolt from cam cover, through head, into cylinder.  I'm ready to hurt someone.
Any useful suggestions on how to fix threads that pulled out of a 4 1/2" deep hole?  I have no interest in removing the head... AGAIN.
Edited by exdirtbiker
I used a 1/4-20 bolt in it's place and it worked fine, I didn't even tap it for all the same reasons.. really didn't want to take the head off.. I did run a 1/4" drill as far down as I needed to go though
That bolt should be m8...
Til it gets upgraded which I doubt, oil up the threads and either handtight it or be torque specific, dont just crank down.
The threaded section popped off on a dissassembly and this is when I was told to use a bolt and nut. A man of greater experience put me up on game. But I used an extractor and removed the snapped off piece and left the females in fine shape. Then $4 for the proper oem bolt cause of course I didnt have 115mm long m6 bolt in my piles.
And use a nylock nut. But next time you have the head off, just put a timesert in there.
I fixed it by using a 4 1/2" long, 1/4-20 AHSC with 4 little flutes ground into the first 2 threads = "self tapping screw".
the 6mm is .230", the 1/4 is .250.  not alot of material to work with, but it only needed 9 ft-lb of torque to do its job.
it works.
 Thanks to all :-)
I did exactly the same thing... except I didn't even bother with the "flutes", just ran it in and called it a day.. did it on a couple of them.. I think I had a 4 1/2" I used which had more thread engagement.
2 nights ago I felt one of the cylinder head bolts go weak on me as I torqued it.. I made my own time serts for that pair.. the other side had previously been stripped out and I used the cylinder bolts (cylinder to block) which are 10mm, and drilled and tapped the cylinder and the head to accept the bigger size.. works really well..
10 hours ago, skorpan777 said:
Helicoils are just perfekt for that
That is the correct tool for the job.  But... I would have to dis-assemble the motor again to do it.
When I rebuilt my XL600, I helicoiled EVERY BLEEPING ONE.  I didn't even think about it during this disaster. Call it a "senior moment"?
helicoils are weak in weak base metal..  Timeserts are definitely a step above.. I'm lucky i had the capability to make my own when I needed them since I live out in the sticks
  • Like 2
