Torque Wing on a 2-Stroke
Hey Gang, anybody have any experience running a "torque wing" or airbox splitter on a KTM 2-Stroke? I'm forgetting some of the brand names, but I'm talking about the thin metal plates that form a cross or X that go between your carb and air filter to create turbulence within the air intake. I know they can have a truly positive impact on 4-stokes, but I don't often hear anyone talk about running one on a 2-stroke. Maybe because the air gets moved around the engine so much in a 2t that it's mostly redundant?
What do you think?
If you are gonna do it, have RB put one in the carb, anything else is conjecture at best.
Edited by DEMI
Yep,
I had RB Designs do the carb mods and cylinder head mods on my KDX200 and KTM 300 XCW.  Very pleased with results and significantly improved the low end on both bikes above 10K+ elevation.
www.rb-designs.com
2 minutes ago, SilvFx said:
Yep,
www.rb-designs.com
I had it done on a couple different bikes, the full set up. Ron is the man.
the dividers in the carb work well, IF you ride at low throttle alot.  On a MX track, not really noticeable.  with a 36mm carb on a 250 it isnt such a big difference.  On a 125 with a 38 it is huge.
I didn't buy one, I built some and tried them in my 125 and in a 1000cc Kawi. As Rebel mentioned, improved low throttle response but in both cases seemed to impede full throttle power.
Which is what would be expected. Its a huge flow impedance. Might help at half-throttle and below, has to hurt at WFO. Also note, the flow thru a carb on a case reed induction two stroke is very strange, as it starts and stops as the reed closes. The air doesn't stop, it reverses and a pressure wave flows out the carb to the airbox, then it reverses again. Its really weird. On road racers (which use a naked carb) you could sometimes see a cloud of fuel/air mixture in a standing wave an inch or so away from the carb entrance.
Pat, non-reed 2 strokes are even worse. Many of the early snowmobiles were piston port induction and if run without the spark arrestor intake screen (so you could prime them to start in -30) would have the fuel cloud you mention. If it backfired, you had a fireball on your crotch!
