98 250sx
Im picking up a 98 250sx tomorrow with 8hrs on a fresh rebuild. I know in 99 or 2000 is when they went to hydro clutches. Would any of those years bolt right up to a 98?
Can be if you get the right parts. Won't be as simple as buying slave, line, mc...
99 was the first year.
The actuator rod is probably different, etc. More or less the same bottom end, the left case will be different because of the hydro. If it was me, I would just run hymec unit, unless you can find a used bottom end maybe.
What is the seller looking to get?? The handlebars, levers, brake pedal look shagged. Any proof of rebuild?
  • Like 2
New wiseco top end and head
new fmf header
new tires
throttle cable. Bike runs good. Have levers and pegs at my house that fit and work. Gotta get a new rear break lever. Traded a 99 wr400 basket case for it. Only issue im having is i think theres a bushing missing on the clutch cable side.
Yea. I just had to mAke a bushing so the cable doesnt drop all the way down in the case.
