Fork seal replacement help needed
I recently bought a 2006 Gas Gas 300 txt pro that Jada busted fork seal. I called the local shop and they want to charge me $250 to replace it. So I am going to try and do it in my own. Anyone have any good resources on how to do it?
3 minutes ago, Bermudacat said:
First, go to Harbor Freight and buy a seal puller. :thumbsup:
Can you give me a link to the page?
RSU forks typically are held together by the top cap threading to the damping rod. Been a year since I've been into mine.
Try here;
https://www.youtube.com/results?search_query=2006+Gas+Gas+300+txt+fork+seal+replacement
One important note: Back your clickers all the way out when you re-assemble your forks. Cleanliness is Godliness, yada yada.................... :D
Try here;
31 minutes ago, Slicing-Air said:
Youtube
I have looked through a bunch of those videos and unfortunately non of them have a good start to finish "how to" on replacing the fork seals.  I don't want to get started only to realize that I don't know a few steps.
  • Like 2
You dont need any spcial tools, to pull the seal pull out the cir clip and pull both halfs of the fork apart. To get the seal on the lower fork put grease on the inside of the seal and cut a ziplock bag diagonally and put that over the lower fork leg and slide the new seal on. To seat the new seal; leave the old fork seal on the bottom half then put the new seal on. Then when you put the 2 halfs together, use the old fork seal to seat/drive the new one by pushing it down on top and using a rubber mallet. Then just cut the old fork seal off.
You do realize that the Gas Gas txt doesn't have USD's right?
Apparently not.
Do you have the manual for the bike? :)
On 9/16/2017 at 8:26 PM, JHensel said:
I wish
I was on Lewisport's website.  They have access to a ton of owners manuals and service manuals for a lot of trials bike.  But nothing for GasGas.  Bummer.
