Ktm open chamber fork preload
I've read that ideally you want 5mm of preload, when I installed new springs my preload is just over 6mm with the preload adjuster on the fork back off. Should I remove a washer to decrease the amount and then fine tune with the adjuster on the fork cap? Thanks
You must keep a washer on to allow the spring to rotate
Right now I have the thinnest washer installed and the preload turned 2 times to give me roughly 5mm, is this correct or should I put both washers back on?
