2016 WR450 Electrics
Hey Team.
I am sure I have read similar threads about relay and electric corrosion with the 2016+ years wr450 and FX models. I found an issue with the spade terminals factory fitted on the ignition coil mounted under the fuel tank. This effects 25ofx as well, as a mate is on his second coil now. The terminals are connected with the covering boot face up and therefor prone to collected water from wash down. I have sprayed every electrical connection with crc226 anyway, but this one is an even easier fix. Simply turn the terminals over so the rubber cover boots face down. (...and spray with crc226)
Happy riding
  • Like 3
