Matching parts for front end.
Long story short I looped my 2014 SM and front forks aren't in the best shape and snapped my top triple and bent my lower triple. I've been trying to find a new assembly with forks and triple that aren't beat to shit and I am not about to pay $900 for a used set. I've found S model forks and triple in great condition for $300 all day so I am considering going that route. The issue I am running into though with swapping over to the S model front, is the front brake. I know I would require some kind of bracket to be able to use the SM front rotor.
Are the mounting points on an S and SM model front caliper the same?
I know I would require a relocation bracket but if I order one for an S model, will the front SM caliper mount up to it?
Anything else I need to know before pulling the trigger or do I bite the bullet and spend $500 more to go with the original stuff?
Because the SM forks themselves are $400+ and the clamps are $350+ . Need to replace both of em.
I could just be over thinking this and if the S and SM both use the same front caliper its not an issue at all.
Just now, ohiodrz400sm said:
How far?
Not terribly. Its more like the right one has a small dent on the inside tube.
If the tubes do not have a crease, they can easily be straightened and be as good as new.
Edit...oh, a dent, tube is trash. I'd speak to a ;large suspension shop and see about a replacement non-OEM tube. Parts direct from the suspension company are often a lot cheaper than when middle manned by the Biker OEM.
Only problem is I haven't got a clue into the world as to where I could get that done at near me. Nor any idea how much that would cost to be done.
The forks are 47 MM Showa Twin chamber forks. They were used on Suzuki RM's since 95 and Honda CR's since 97. I suspect the taper is probably the same as the 2000's RM's. I would research p/n's if I were you. You could probably buy a set for cheap and use the outer tube with your internals.
  • Like 2
