15 FC350 wiring
So, I was installing an upgraded stator from Ricky Stator and ran across a couple of bad wires.  You guys with FC's, might wanna check yours out.  It's the wires that go to the regulator/rectifier.  An easy repair, but if you get stranded somewhere, this might just be the culprit.  Also,  has anyone else done the stator install?  Those (4) bolts inside the ignition cover are a BITCH to get out!
Edited by Chadolson
spelleeng
