2001 cr250 transmission install
Hi I'm getting ready to put my cr250 case back together and was wondering if you guys had any tips or good videos of installing the transmission. This is dt he first one I have done and want to make sure I do it right :) thanks for your time and have a great day
I just put mine back together last week. Just make sure you get all the little spacers(washers) back in place on the shafts. Dont forget the breather hose.
Dont hammer on anything real hard, light taps with a soft dead blow only. Heat the left side crank bearing with a hot light or hairdryer first and put a bag of ice on the crank too.
Lightly tap, then use the bolts to draw the cases back together evenly as possible.
Test the gears when finished.
Don't hammer on anything. Follow the manual closely and use a crank puller to close up the cases. make sure your case dowels don't have any rust or dings. Should go together like HILLARY AND CORUPTION.
  • Like 2
