How to remove clutch basket the easy way
Yesterday I had to remove my clutch basket to get to my shift stopper in my 05 yz 125, I don't have A clutch holding tool, so what I found to work was to put the brake lever back on and put it in first gear, then stand on the brake as I remove the nut. This only works if the motor is still in the bike. If the motor is already out, what I did last time was pack a rag evenly around between the inner and outer clutch hub, put a screw driver between the gears and pull it off that way. Just thought I'd share that with anyone who might not have the tools. Both ways worked easily and didn't cause any dammage
  • Like 2
