Clarke Tank - leaking
Hi all,
Recently purchased a Clarke tank to replace my old cracked tank.
problem, the petcock does not seal properly against the tank. I have purchased a new o ring but still no proper seal, I can only assume it's not level.
Can I stack multiple orings on top of each other to get a better fit?
I stupidly used a silastic out of desperation to get it back on the road but I know that's not a great solution.
whats the easiest way to get this sealing permanently?
Very disappointed with the quality of this tank, the moulding just in general is very average for a au $400 tank.
petrol resistant o-ring ?
any pics ?
might be some defects in the plastic not letting it sit flat
Yep. I have been using Clarke since '73, never had a quality issue. Have a new one on my XR4. That $400 sounds ridiculous, where did you pay that? I would bet Clarke or the seller will make it right.  Lots of liability involved.
Same issue with mine. Clarke sent me some Vinton gaskets.  I used the thickest one.  I'm pretty sure I left the O-Ring in there even though it was leaking if only to take up some of the space.  They wanted me to do modifications to the tank, but I didn't want to go that route.
It's been leak free for two years
Thanks for the suggestions, if I can't get my money back I'll try the suggested solutions.
looking at it closely the left screw hole is very raised and the plastic flexes out even more when trying to tighten it.
And yes they are $400 in Australia.
Edited by Chicken Mac
Make sure the bolts aren't too long and bottoming out in the insert.
Nah they are all good. Re-fitted my old tank with the same oring etc and no leaks. Might just try and plastic weld the cracks in the old tank and forget about using the new one. Still waiting to hear back regarding a refund or anything.
3 minutes ago, cabrito said:
Ask them to send you some of the Vinton gaskets I showed you earlier.. Super simple fix.
I'll try but i'm having to deal with the Australian Distributor I cant go via Clarkes direct.
