Piece of metal in crank case...
So yesterday i lost a quite big piece of metal when trying to put the Cylinder back on mt YZ400F, and i cant find it anywhere! Im pretty sure it fell into the crankcase... And the part was non-magnetic of course...
Is there any "panels" i can open to see if i can see it? Or is the only option to split the engine?
Appreciate all the answers!
Got all winter to fix it, so time is not a problem :)
Try one of the small USB or bore scope cameras.  Can you invert the engine and shake it to try to get it to fall back out?  Try to put some duct tape on a piece or copper wire sticky side out and try fishing for it.  Connect a small hose to your vacuum and see if you can snake the hose into the area with the loose metal and suck it back out.
