compression spec with auto release ?
Have a KLX250s 09' and I want to check the motor's compression.
I've never did a compression test on a motorcycle before.
From reading online and seems like there is a mechanism for automatically releasing compression that will give inaccurate readings?
I was reading my repair manual and it says I have a KACR (Kawasaki automatic compression release).
But, can I test that the compression is within spec WITH the KACR?
12 hours ago, Confederate said:
Since you have a manual, how does it say to test compression and what the proper spec is?
Woops! I just checked again and found it.
Idk, this morning I checked it by searching ctrl+f "compression" and couldn't find it.
http://mototh.com/files/kawasaki/KLX250/Kawasaki-KLX250-Service-Manual_new.pdf
chapter 5 page 24
it does say"useable"  psi  should be @ 94 - 149 psi.
so should I interpret "low compression" to be less than 94 or (94 - 100)
Edited by horrorfan
