Dr250 acts like there's no gas
So I was driving about 10 miles down the road with a full tank of gas and had the petcock on 'ON' and as im riding it starts to lose power so I pull over and make sure that my gas is on and as I thought yes it is on but it still tried dying so I put it on RES and it continues to run fine then I start to come back home with it in the ON position and it does the same thing so I put it back onto RES. I don't know what it could be I have a full tank eith only 28 miles on it so far. And I should be able to get at least 120 miles from a full tank
Those fine mesh screens inside the fuel tank can get clogged up with debris.  I had a bike that did exactly what you describe, it wouldn't run in the on position but it would run fine in the reserve position.  That was because the petcock filter screen on the main feed tube was clogged up with junk, but the reserve feed tube was clear as it hadn't been used hardly at all.
14 minutes ago, S.O.A.N.Z said:
Drain the fuel - remove petcock - the longer tube will be blocked
The longer tube is the regular fuel pickup.  The shorter one is the reserve fuel pickup.
Ok thank you
I will keep updated
