EE rad braces with fan
for people who have installed the EE radiator cages/braces - where did you mount the temp display? it's not the end of the world if i don't use it, but wouldn't mind using it. On the EE setup you toss the OEM fan brackets. I bought the husky fan kit for my 17 fx350 to fix my boil over issue ever since i put on the EE rad front protection.
figured id post an update in case anyone ever searched with same problem - this is how i went around to make it work
cut down the fan bracket as shown, drill and tapped 2 holes in the side of the EE brace and drilled one clearance hole before the existing on the fan/temp bracket. I  used the 2 screws included in the husqvarna fan kit and bolted it to the side of the EE brace as shown. Also used a longer bolt with nylock nut to hold the other mounting spot for brace/fan.
Edited by slothy
