XR400 freshen up 426 or ?
 I'm getting ready to freshen up the top end of my xr400 and I'm trying to decide between this kit http://www.ebay.com/itm/Honda-XR400-XR-400R-88mm-88-426-Big-Bore-Top-End-Rebuild-Kit-Cylinder-Wiseco-/191719616844?fits=Model%3AXR400R&epid=848902216&hash=item2ca361314c:g:ouEAAOSwYGFU1-WQ&vxp=mtr or taking my cylinder in to the machine shop and having it bored to 407 or 415. Either way I will try to stay around 10.1 compression with a Wiseco piston. It would be nice to have the extra power from the 426. I'm also considering a stage 1 Hot cam. My main concern is I do follow my 11 year old son on his xr100 some so I don't want to run into over heating issues in warm south Texas, but I also am starting to do some hare scrambles so it would be nice to have some more power over stock. I already have a Mikuni carb.
Thanks,
Andrew
i would have thought the gain in the CC increase you suggest would be minimal, the refresh will perk it up.
But then again, when I ride my XR400 off road, it has more power than i think anyone could really want. It'll pull my 100kg bulk up a hill chugging away and still give more when i open the throttle (Edelbrock carb). I can't imagine another 5hp would add to the experience much at all. On the road I get more power might help, but I try to keep off the tarmac to preserve the knobblies.
standard is pretty good
I went from the stock 398cc straight to 440. The extra power is great. A big bore with the Mikuni you already have is a great combo. Big bore plus hot cam is a little much I think. I was concerned that there's not much you can do to beef up the bottom end and the rest of the engine to reliably handle massive gains long term. I kept the stock cam with no regrets. The extra heat with my 440 is easily managed. I would think a 426 more so.
Don't forget the clutch. If it's time for a top end, then it's also time for a clutch. The extra power and torque of a big bore will expose a worn clutch and weak springs.
Ditto the clutch.
I did it all, 440cc, HRC Cam, TM40 pumper, XR's only complete exhaust. I race Harescrambles and I follow 5 year olds on 50's. No overheating in Oklahoma.
The power is great, but the XR is by nature happy at low speeds due to low gearing and heavy flywheel.
4 hours ago, Firestone said:
Ditto the clutch.
Which big bore kit did you go with and what is your compression ratio?
