Kickstart shaft
Hey everyone, the other day my kickstart shaft decided to break on me on my 20170918_152022.jpg99 kx250, can't seem to find anything available online. Does any other year or model could possibly work that you know of? Thanks in advance
99-01 use the same shaft, earlier models may work but the part numbers don't cross over.  02 and later use a larger and stronger shaft but you would need the side case and matching kick lever as well.  Would probably be worth it to upgrade.  02-04 would work.
Edited by turbo dan
  • Like 3
Would a kick start shaft off a 98 125 work? Parts numbers
Kx250: 13066-1099
Kx125:13066-1101
I doubt any 125 parts would fit.  Almost no chance.  Only 250 stuff.  That's what I assume yours is.  Looks like one.
  • Like 2
Ok I just went through this a few months ago , that Kickstarter shaft for 99.00.01,kx250 is next to impossible to find you can use one off a 98 ,97 and so on. The kx250 has the same kicker from 94-01 I believe ,I used a 98 in a 01 only thing I did was swap the lil clip from my old one onto the 98 seems like the 99-01 shaft was very hollow that bolt hole snaps off I've seen like 4 now break .
  • Like 2
I have a customers bike in the shop for the same thing. 2000kx250. got a 98 kickstarter shaft for it and will see how that goes. I have a 99kx250 also , so I am seeing if this works, then will get another for spare.
  • Like 2
Got it back together in no time. Easy job, also found out it has Hinson clutch basket in it! Bonus! Thanks for the info guys
I just fixed mine 2001 kx 250 (13066-1099) can not get one. I found one 2002 kx 250 (13066-1107) this is what I did. the gears and snap rings fit as they should, the shaft that goes out to the kick lever is thicker so I popped out the seal (with out damaging it) then drilled the case out to 13/16 the new shaft was a little tight made  32 second bigger shaft fit perfect new gasket put case back on bolted, put the seal back using a socket. then ordered a new boss to fit the shaft (Boss 13061-0057) 68.00 the 01 kick lever is the same, now I'm going riding Sunday  most likely will not brake again much thicker shaft...
  • Like 2
