Dualsporting 480rr
On 10/6/2017 at 8:01 PM, Nicolarr said:
How often do b u guys change engine oil and tranny oil. And what kind of oil do you use?
So far I've ended up changing oils around 20 hrs. I don't see the need for shorter and may spread it out a tad if need be for longer rides.
I've been running the Motul spec'd engine oil and testing different trans oils.
Currently I'm running Mobil 1 multi-vehicle full synthetic ATF in the trans. Shifting and clutch action is definitely better than with the Motul Trans expert. I might try some Amsoil Dirt Bike Trans oil but it's a pain to buy (online only) and I'm not sure about the SAE 80 weight for the draggy Beta clutch.
  • Similar Content
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
    • By Woody Oakson
      So I have a 2008 yz450f and I would like to add some LED lights to it to make it street legal. Mainly just a headlight and a tail light and turn signals if I need to (which where I live hand signals work).
      So where I need help is getting power from the stator to a battery. Wiring from a battery to anything else I got and understand and don't need help with (but recommendations are welcome). So my questions are.
      What type of power is coming from the stator. AC or DC? Will I need a regulator or rectifier? How do I wire something from the stator to charge a battery? What would that wiring look like? Would this stator http://www.rickystator.com/product/stators/yamaha/yamaha-yz450f-35-watt-lighting-stator-assembly-06-09 work? Anything else I should know? Any help would be appreciated. Thank you.
    • By Bigair01
      Hey Guys I thought I would share the placement of my WISECO Fuel Commander.  Please subscribe to my channel, share or like it.
      This video shows the steps needed to install the WISECO Fuel Commander Controller for the Fuel Injection system on my WR250R.  This install can be difficult if you don't know what you are doing.  But hopefully the video helps you figure out the steps needed to install this thing.  If your not comfortable have a Mechanic install for you.  I definitely felt a snappier feel along with my No Toil Air Filter Mod.  I bought this in hopes to have the capabilities to properly fuel my bike during stock and new exhaust mods.  Well When I get it anyhow.  SO if you liked the video please check out all my current and future videos on my channel.  Cheers.
    • By Markl5557
    • By LRB
      Hey guys,
      I currently ride a WR450F that is not street legal and would like to pick up a dual sport to make things a little more flexible for me when I travel to Southern UT to visit family. I dont really want to make my current bike street legal and just figured it'd be fun to have a dual sport to dink around on when I am visiting family.
      I dont think I am very interested in the DRZ mainly because I don't think it'd get a ton of use and don't feel like spending that much for something that I am not too sure will see much use.
      Wondering what your thoughts are on advantages of the CRF250L vs WR250R vs KLX250 are and anything you think I should consider when looking at these models.
      I think the only challenge that the KLX has is that there arent a whole lot of aftermarket options for the 2018 model yet, but I am sure those will come soon enough.
