Mikethe80srocker
Koyo v/s SKF Crank bearings
13 posts in this topic
I have the option of either installing SKF bearings or Koyo bearings . I was told by my local parts / Bearing retailer that SKF makes high quality brgs .
Koyo have also earned a great reputation being a trusted brand as well .
I'm seeking the opinions of the forum on this choice .
Thanks for your input on this matter !
Application :  1984 YZ 250L
I really don't think you can go wrong with either.
2 people like this
Koyos are made in Japan.  Some of the SKFs are made in Mexico.  They both have a good reputation, but if given the choice and price being equal I'd go with Koyo.
1 person likes this
Crank bearings often have other than normal clearances so check with the bike mfg before buying, or buy OEM.
Other bearings will be normal clearance so anything will work. Wheel bearings usually fail from contamination so buy sealed.
When looking at SKF or Koyo brg numbers , what part of the part number pertains to the internal clearance ? Or , does it even work that way ??
Thanks for the heads up info  !!
If I recall correctly, one of the number is a hardness factor. FWIW saving a couple bucks on mains isn't worth it to me. Yamaha uses Koyo and that's what I put back in.
1 person likes this
I stoped by my local Yammy dealer and asked about the crank bearing clearance spec of the OEM bearings , and he told me that its not a spec that listed in the repair manuals or part microfiche .  Does anyone have this info they would mind sharing  ?   Thank you !
The additional clearance (c3 or c4) is due to the double interference fit seen in crankshaft applications. Most bearings without specified clearance are CN which is between c2 and c3. and could potentially end up being to tight when the outer race gets smaller and the inner race get larger due to the interference fits. CN is designed for just one race to be in interference and C! and C2 are for precision applications with very accurate light fits
Koyo is at least factory yz bearings, my crank bearings lasted I believe 17 years, I didn't buy the bike new but have owned over 10 years. Just did a complete over the winter. Factory brand in there at least
Talked to a local bearing supplier guy today , and told him my situation , and he said without any doubt a good quality brand with the C3 will work 100% in that application .
He wants to sell me a pair of these : SKF 6202-2RS1/C3 ( Made in the USA )
1 person likes this
  • Similar Content
    • By Medard
      So i just rebuild my top end of my 2005 250F, i had 35 houres on my piston and cylinder so i decided to rebuild it.
      it ran perfectly before the rebuild, my timing is right, i have spark, en my sparkplug is a little wet so i have fuel... If i try to kick it it starts to run but after 2seconds it stops running. does anyone know what i have to do?
      thx Medard from belgium
    • By Henry Gooner
      Hey Guys,
      So I am 270# and 6'. I used to ride and want to get back into it. I definitely have a good amount of experience to handle both a 250 and 450 but not sure if a 250 will be able to handle me.
      Right now the bikes I am between are:
      2012 YZ450F @ 50 hours for $4000 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1302150376&requestSource=b 2012 KX450F @ 35 hours for $3800 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1300722287&requestSource=b 2010 CRF450R @ 45 hours for $3200 CAD and trail ridden https://www.kijiji.ca/v-view-details.html?adId=1296942462&requestSource=b All these bikes are in really good condition from what I can see from the pictures and none of them raced or track ridden. My plan is to build a 5 acre track in my backyard and build some sort of track along with mainly using it for trail riding.
      I guess what I am asking is for some suggestions and opinions that could help me decide.
    • By short450
      Very nice Rekluse Core EXP 3.0 Clutch that has been ran for about 40 - 50 hours.  The Core EXP 3.0 gives you the best of both worlds as it is fully automatic and allows you to operate it just like you would a manual clutch.  Was getting ready to install in a 2017 YZ250F so I wanted to freshen it up and bought a brand new EXP 3.0 Disc which has never been oiled up or installed.  Before getting time to install the clutch, I decided to sell the bike.  It fits a 2014 - 2018 Yamaha YZ250F.
      ONLY $575 shipped anywhere in the lower U.S.
      Please call or text me at 801-362-8899.
      Thanks!
    • By 27latemodel
      2006 Yamaha WR450 CA street legal, low hrs clean bike, desert tank and stock tank, FMF muffler 3800.00 obo
    • By Wes Watson
      '06 CRF450r here.  I have a rear Talon hub with excel rim.  Bought the bike about 18 months ago and since day 1 have noticed a very slight side to side play in the rear wheel.   If i grab the highest point and lowest point of the wheel with bike on stand and shake the wheel back and forth I get about a millimeter of play.
      I've had wheel bearings replaced twice, by two different mechanics.  Spokes are tight.  Everything seems like it is the way it's supposed to be but no matter what, the play still exists.  It has never gotten better, never gotten worse.  I've owned several bikes in my life and have NEVER experienced wheel play before; then again I've always ran OEM hubs only.  Ideas/thoughts?
