Nodachisword
2001 DR200SE turn signal problems
2 posts in this topic
Hi there,
I bought a 2001 DR200SE a few weeks ago and it was missing a turn signal so I replaced it. Now the right side when turned on just stays on and doesn't blink. The left side does the same but the front left bulb doesn't go on, I think that might just be a bad bulb. Could this be a relay problem?
Thanks,
Maddie
If the blinkers are on solid that would indicate a faulty blinker relay. I recommend buying the shop manual for the DR200SE which I did and found indispensable. I’ve had to work on the carburetor and couldn’t have done it without the shop manual. Also when I did valve clearance adjustment.
